• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    Active Contributor
    a06vsh
    revit 2013 not responding when saving
    316 Views, 4 Replies
    10-15-2012 04:13 AM
    Ok, so i've googled the problem but without any success:
    When working with certain files, not all but always the same ones, Revit stops responding when I try to save the file.
    If i save it to a local harddrive it always works fine, but that cant be how it's supposed to be, not being able to save files on a server?! I've tried linking the file to a new one and then binding it, but still with the same issues. It's not a matter of large files vs small files working or not working. And it does the same thing with the same files no matter what computer i use at the office.
    I've run out of ideas, need help!
    Victoria
    Please use plain text.
    Active Contributor
    a06vsh
    Re: revit 2013 not responding when saving
    11-07-2012 02:39 AM in reply to: a06vsh
    Anyone with the same problem? Or a solution?
    New Member
    11-07-2012 05:04 AM in reply to: a06vsh
    my siggestion is uninstall this and reinstall it properly
    Revit LT Revit LT Suite
    Active Contributor
    a06vsh
    11-07-2012 06:56 AM in reply to: juwelunlimited
    Already tried unfortunately.... And it's also the same on all computers, and always with the same files. But enough files for it to not just be a one time bad luck.
    Active Contributor
    a06vsh
    Re: revit 2013 not responding when saving to server
    01-07-2013 06:07 AM in reply to: a06vsh
    Kicking this back up to the top since it's still a major issue at the office.
    Does anyone else have the same problem? And even better; does anyone have a solution?
