• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    New Member
    revit 2012 backgrounds on elevations turning black and display option
    252 Views, 2 Replies
    06-25-2012 12:23 PM
    I had a few exterior elevations (actual design elevations not 3d) of a building that looked great and had nice shadows and materials and everything was wonderful until today when I turned off a couple section marks and a level mark and then the back turned black and the dialog box in Graphic Display Options does not show the background section anymore?????
    Now I can't even get rid of the black background!!
    Any ideas?
    Please use plain text.
    New Member
    Re: revit 2012 backgrounds on elevations turning black and display option
    06-25-2012 12:54 PM in reply to: mhopkins
    I also tried the few options of hardware acceration or not and anti-aliasing but nothing has worked...I hesitate to mention it but i did do a windows update also.
    Could it be a direct x problem?
    Product Support
    fernanda.firman
    06-27-2012 03:55 PM in reply to: mhopkins
    Please check if Revit has the latest update installed and the drivers for the video card is uptodate.
    Can you reproduce the issue in a new file?
    Fernanda Lima Firman
    Revit Support Specialist
    Revit Clinic
    If this helped solve your issue - remember to 'accept as solution' to help others find answers.
