• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    Member
    Anonomyous57
    reference planes in 2012
    612 Views, 8 Replies
    09-16-2011 11:24 AM
    I am learning to use Revit 2012 and having a hard time figuring out why basic drafting features don't seem to work with reference planes. Aligning more than a few of these one-at-a-time is time consuming and frustrating - Does anyone know if there is a way to extend multiple reference plane lines to a boundary line or object? I read your instructions for offsetting reference planes - when I select the reference planes button in the home tab, the options bar allows me to set an offset distance but I am at a loss as to how one goes about getting the line to offset - I keep getting the layout dimension when i try to click on the line!
    Edited by
    Discussion_Admin
    *Pro
    Alfredo_Medina
    Re: reference planes in 2012
    09-16-2011 01:20 PM in reply to: Anonomyous57
    What would you get by aligning the ends of reference planes? They are considered infinite, and the line you see, long or short, is just a representation. They don't even print.
    To create a new reference plane with offset, don't use the Offset tool from the ribbon, because it does not work for reference planes. Instead, use Home > Reference plane > at the options bar, type the offset distance you want > from the drawing tools use "pick lines" and select the line or plane that you want to use as a reference for the offset.
    Planta1 Revit Online Consulting | info@planta1.com
    Member
    Anonomyous57
    Re: reference planes and joining separate masses in 2012
    09-26-2011 03:20 PM in reply to: Anonomyous57
    Thanks Alfredo - much appreciated. Any thoughts on options for extending layout lines en-mass in a manner similar to how one would use the fence command to extend or stretch multiple lines in Autocad?  This would be a big help as well.
    Care to help out with another novice question?  I made a series of masses in Revit 2012 during a tutorial but accidentally saved each mass individually using the 'Finish' button before I realized that I needed to join the masses. Is there a way to join masses after-the-fact? I tried to go back in by using the edit-in-place button, but I am not able to include any other masses in this editing session in order to select them during the join command sequence.
    *Pro
    Alfredo_Medina
    09-26-2011 07:53 PM in reply to: Anonomyous57
    For extending multiple lines use Modify > Trim/Extend Multiple.
    For joining different masses use Modify > Join Geometry.
    Member
    Anonomyous57
    09-27-2011 07:58 AM in reply to: Alfredo_Medina
    Many thanks again!  Have learned about 'extend multiple' for lines recently but worded the previous question inaccurately, I think - Is it possible to extend reference planes in a similar manner? (being new to the software, I keep thinking of them as 'layout lines') I could see it being helpful for plan layout, etcetera to be able to extend the visible segment to a boundary. For example; an interior wall centerline to an exterior wall centerline.
    *Pro
    Alfredo_Medina
    09-27-2011 08:43 AM in reply to: Anonomyous57
    No. The Trim/Extend Multiple tool does not work with reference planes.
    Valued Mentor
    09-27-2011 07:44 PM in reply to: Anonomyous57
    If you're trying to extend reference planes, I think you're missing the point of what a plane is.  They are not meant to be construction lines, the represent a 2D plan that is infinite in every direction perpendicular to the plane in which they were drawn.  There's no need to extend the visible representation of a reference plane, because they are infinite.  If you really want to trim/extend something, you'll have to use either detail lines, model lines or reference lines.
    Ross Kirby
    BIM Manager
    Arcturis
    Member
    Anonomyous57
    Re: reference planes in 2012 and the bigger picture
    10-17-2011 01:48 PM in reply to: Anonomyous57
    Hi Ross,
    Thanks for the explanation. I think you are correct- I am missing the point about the intended idea and use of reference planes as well as other similar ideas relating to Revit 2012. Having learned to use a number of 3d modelling and cad programs effectively, I have found that the real learning typically begins after a basic understanding of the conceptual framework of the program takes hold but I have not yet found a source of information that offers this kind of explanatory information in any form. Do you (or does anyone else) know of a book that can help one understand the basis for how this software is organized? I have a tutorial book which is walking me through basic functions, but basic acts of working efficiency such as changing the height of several walls by pulling their bottom edges down at the same time (formerly a shift or control multiple selection) are not possible with contectual menus. I know there are ways to do these things but finding out how has been really involved and I think is rooted in a lack of understanding of the big ideas used to design this program. Hoping for some help and a great deal more insight. Thanks!
    Valued Contributor
    adave
    02-08-2012 10:42 AM in reply to: Anonomyous57
    anonymous57
    Looks like you started out on this journey into revit about the same time as I did.  Did you find any good reference or training sources for noobs?  I've been watching individual tng videos on Youtube, which are great, but a bit piecemeal.
