• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    Member
    maskelllee
    "A serious error has occurred" - Revit 2012
    135 Views, 1 Replies
    02-09-2012 04:23 AM
    Every time I try to add two custom wall sweeps to a wall I get the "A serious error has occured. The current action has been cancelled, etc etc"
    Is this a bug within revit as I have tried mutliple methods including a standard out of the box revit wall which does contain two wall sweeps (ps I mean in its structure build-up as opposed to adding a sweep on manually through Wall>wall sweep function), and amending this to have my profiles?
    I have added the two profiles individually and they work fine. Anyone else experienced this problem?
    Lee
    Distinguished Mentor
    Re: "A serious error has occurred" - Revit 2012
    02-10-2012 04:56 AM in reply to: maskelllee
    I have experienced this on occasion with sweeps built into the wall.  I found that redoing the sweep from scratch worked.
    Hope this helps you.
