• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    Active Member
    printing problem
    113 Views, 3 Replies
    11-21-2012 02:32 AM
    I am having problems Printing A1.
    On the pictures you can see the the plotter setup and how the preview looks, I think i have tried anything to make this work
    Any suggestions?
    The driver of the printer has been recently updated.
    Please use plain text.
    Re: printing problem
    11-21-2012 05:14 AM in reply to: sigurjon81
    Nice, it looks as though the image is hanging off the paper. If printed, does it come out correct?
    Corey D.        LogoEE.png   AutoCAD user  Revit user
    ⁞|⁞ Please use the Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos functions as appropriate to further enhance the value of these forums. Thank you! ───────────────────────────────────────────────────────────────────────────────────────────
    Active Member
    11-21-2012 05:33 AM in reply to: CADastrophe
    No, It prints like it looks in the preview, the whole sheet is slightly of the paper to the bottom left corner
    11-21-2012 05:46 AM in reply to: sigurjon81
    To answer with questions:
    1. Have you restarted your computer since the driver update?
    2. Does any other application have this issue when printing, or is it just Revit?
    3. Are you able to use 'Offset from corner:' to "push" the image back onto the sheet?
