• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Revit Architecture
    brian.dougherty
    need hellp
    107 Views, 2 Replies
    05-04-2012 10:05 AM
    I can't load any glass curtain doors from seek or revitcity. They won't load as a component or door.
    I can't place a door into a storefront wall. I get this error saying something like,"cutting surface doesn't not work" I tried to adjust the mullions so that the door would fit, but it still doesn't work.
    Can I demension the interior side of a wall when the wall justification is centerline?
    Is there a way to calculate the roof load in revit?
    Please use plain text.
    *Expert Elite*
    Alfredo_Medina
    Re: need hellp
    05-04-2012 10:23 AM in reply to: brian.dougherty
    I suggest that you open a new thread for each question.
    Planta1 Revit Online Consulting | info@planta1.com
    parveen.revit
    Re: need hellp
    05-07-2012 09:37 PM in reply to: brian.dougherty
    curtain glass doors are 'curtain panel' and can be loaded as family, use Insert Tab, Load Family Button (it won't load into door category).
    To place a door in curtain/storefront wall, you need to choose one curtain wall panel and replace it wtih doors using properties menu (after loading the curtain panel doors into project).
    You can easily dimension any layer of a wall by pressing TAB button while dimensioning.
    Revit Architecture can not calcuate roof loads.
    Parveen_Intec_Infocom (BIM, CAD, GIS, QS Services' Provider)
