• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    New Member
    Accepted Solution
    nVidia Geforce Graphics cards for Revit Arch.
    910 Views, 2 Replies
    10-17-2012 05:58 AM
    I am about to purchase a new Dell Inspiropn 8GB memory 64bit laptop which comes with a 2 GB nVidia Geforce GT 650M 130W card.
    I will be using Revit 2012 on this laptop and would like to know as this card does not appear on the Autodesk supported card listings (only nVidia Quadro cards there) will it be good enough to work on complex projects. Any advice appreciated.
    Please use plain text.
    *Expert Elite*
    LisaDrago
    Re: nVidia Geforce Graphics cards for Revit Arch.
    10-19-2012 06:12 AM in reply to: martin.mallon
    Autodesk only tests certain vedio cards. Just beacuse a card does not show up on 'their' list does not mean it will not work. In fact my laptop video card NVIDIA GeForce GT 555M works perfectly (I am running Autodesk Building Design Suite Ultimate 2013 with Revit 2013) -but is not on their list.
    That list has created more problems then it is worth.
    AS long as you have enough ram and Ghz you shouhld be fine.
    LD
    If this helped solve your issue - remember to 'accept as solution' to help other find answers!
    You can't think AutoCAD and run Revit.
    Email: lisa@kalblue.com
    New Member
    10-20-2012 03:01 AM in reply to: LisaDrago
    Thanks Lisa.
