• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    New Member
    my building is gray - Why
    190 Views, 3 Replies
    09-25-2012 02:04 AM
    Hello ...
    I have this project that creates some problems. We are a team so we work with local files and central files. there are 5 local files, and a central file on a network drive, all PCs running LAN connection (not WiFi)
    All run Revit 2013
    problems:
    First As you can see in the picture is a large part of the building gray and some are not, why?
    Second wall down the run is on a one 3D view but not on others.
    3rd The wall of Question 2 is not in the plans
    Please use plain text.
    Active Contributor
    subsales
    Re: my building is gray - Why
    09-25-2012 03:30 AM in reply to: 1007919
    most comen thing here are the phase settings.
    check the view settings for the relevant view, which phase the view is on and the phase filter.
    Regards, Kirstin
    LisaDrago
    09-25-2012 07:37 AM in reply to: 1007919
    The First thing I would look at is the wall you are using and that a material has been established and not just the default.
    Second I would check to make sure the exterior side of the wall was really on the 'outside' - the quickest way to check this is to pick a wall and the side with the double arrow (flip arrows) is the exterior side.
    I would start there and if those are all good - I would go to the phasing and visibility graphics.
    Let us know what you find.
    LD
    If this helped solve your issue - remember to 'accept as solution' to help other find answers!
    You can't think AutoCAD and run Revit.
    Email: lisa@kalblue.com
    New Member
    09-25-2012 07:43 AM in reply to: 1007919
    Check VG Wall category Projection/surface pattern
