Note that you can place the ridge exactly where you want it. Start with a flat roof, then highlight the roof, then in the options bar you will see various buttons, on lets you place points on the roof, the one that looks like a line lets you draw a ridge line. then you pick the tool that looks like a dot with up and down arrows to specify the height above the base level you want the ridge at.
