• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    lighting fixtures on electrical plan
    245 Views, 2 Replies
    11-09-2004 12:45 PM
    Our company's usual standard is to show the electrical and the lighting fixture layout on the same sheet, is there a way to do this in revit? I noticed that the light fixtures will only snap when inserted into the ceiling plan and not the electrical plan. Help, thank you.
    Please use plain text.
    *Scott Davis
    Re: lighting fixtures on electrical plan
    11-09-2004 04:11 PM in reply to: nikki
    On the sheet, overlay the electrical floor plan and the electrical reflected ceiling plan. They will snap to each other for placements, then just turn off one view title. "nikki" wrote in message news:18927432.1100033131097.JavaMail.jive@jiveforum2.autodesk.com... > Our company's usual standard is to show the electrical and the lighting fixture layout on the same sheet, is there a way to do this in revit? I noticed that the light fixtures will only snap when inserted into the ceiling plan and not the electrical plan. Help, thank you.
    11-10-2004 10:14 AM in reply to: nikki
    sounds good, thanks!
