Autodesk Revit Architecture
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
join/attac hed wall to stairs
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
can or cannot???
please help me....
Re: join/attac hed wall to stairs
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Stairs will not directly attach (using the Attach Top/Base command) or join (using the Join geometry command) with wall elements. If you are working with straight stairs, you can use a reference plane aligned with the bottom of the stairs, and attach the stairs to the reference plane. Alternatively, you can directly modify the profile of walls to fit with the stairs.
When looking online for the topic of joining walls to stairs, I found the following pages with additional information:
http://forums.autodesk.com/t5/Autodesk-Revit-Archi
http://www.revitcity.com/forums.php?action=viewthr
Lance Coffey
Support Specialist
Product Support
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
thks for the information...
actually i'm build modeling for paint area calculation.....
i need to joint stair with wall because... i need to deduct area from side of wall....
if not ... the area calculation will calculate all the wall surface...
u have any method???![]()
p/s: sorry for my bad english language....
(from malaysia)
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
You could try editing the profile of the wall to exclude the area of the stairs (from an elevation or section view).
Lance Coffey
Support Specialist
Product Support
