• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Revit Architecture
    Active Member
    installation error
    117 Views, 1 Replies
    09-23-2008 02:41 AM
    Our IT made a mistake in installing the revit. Currently the setting of the revit is in imperial setting. Is there a fast way to shift to metric without reinstalling the software?
    tnx..
    Please use plain text.
    Distinguished Contributor
    Re: installation error
    09-23-2008 04:32 AM in reply to: mcad_marie
    You will have to install metric Libraries and Template files and reset the default paths to point to those metric. Once Revit's default project and family template paths are changed you will have a metric versus imperial environment. Technically imperial and metric setup has nothing to do with the project or family editor, but the template and library files Revit uses to setup a project or family. Mel Persin, AIA AEC Technology Consultant Technology to Visualize and Realize Solutions Modeling for the Future/Drafting in the Present/Building on the Past
    Mel Persin, aia
