• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Revit Architecture
    Valued Mentor
    graphics card
    171 Views, 1 Replies
    07-31-2012 04:54 PM
    I've been given a new machine with quadro 400. It has a certified driver version for running with revt 2012 (I checked on the Adesk certified hardware page) but when I go to options, graphics it tells me-
    The installed video card driver is newer than those certified by Revit.
       Card: NVIDIA Quadro 4000; current driver: 8.17.12.7642
       Certified drivers: 8.17.12.6570
    You may continue to use Hardware Acceleration.
    If you experience graphics display issues, you should:
     - Turn off Hardware Acceleration; or
     - Install driver that is recommended for use with Revit
    Is there something I need to do to revit to get it to recognise I am actually running an Adesk certified driver?
    Please use plain text.
    Valued Contributor
    Re: graphics card
    07-31-2012 11:56 PM in reply to: jmcintyre
    Go to the NVIDIA driver site and download and install the
    one Revit wants.
    If you read somewhere that the 8.17.12.7642 is a certified driver,
    go by what Revit tells you instead, use the 8.17.12.6570.
