• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    Distinguished Contributor
    from straight line to spline line
    162 Views, 1 Replies
    08-16-2012 07:12 PM
    When I draw the detail line (DL), Is there a way to switch from straight line to spline line quickly?
    It's kind of a pain to keep moving the mouse to the toolbar to change the line type.
    I tried to assign a keyboard shortcut to the spline line but it didn't seem to work.
    Thanks in advance.
    Please use plain text.
    Employee
    bellesmum
    Re: from straight line to spline line
    08-17-2012 06:45 AM in reply to: diesellam
    In Revit 2013 and later, there is a keyboard shortcut command called Default : Spline. If you assign a shortcut to this (I used DS), it will change the line type.
    This was a bug that was fixed for Revit 2013, so it won't work in earlier versions of Revit.
    Hope this helps you -
    Lynn Poliquin
    Senior QA Analyst
    Autodesk, Inc.
