Autodesk Revit Architecture
Topic Options
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
*clarkitekt
export sections / elevations
Options
- Highlight
- Email to a Friend
241 Views, 4 Replies
04-27-2004 12:49 PM
Does anybody have a good strategy for exporting to AutoCAD sections and
elevations with lineweights/layers that make sense for this type of drawing?
I know that I can set pieces of the model that are cut by the section to
export to a "section cut" layer, but is there a way for lines of walls that
are closer or further away from the cut plane to export with appropriate
layers/weights?
*Aaron Rumple
Re: export sections / elevations
Options
- Highlight
- Email to a Friend
04-27-2004 02:35 PM in reply to:
*clarkitekt
The way it looks in Revit is the way it will export to AutoCAD. Revit
creates layer settings that represent the pen weights of Revit. Just plot
the AutoCAD file using the lineweight styles as exported and it will look
exactly as it did in Revit. You really shouldn't need any additional setup.
"clarkitekt" wrote in message
news:408eb953$1_3@newsprd01...
drawing?
that
> layers/weights?
> Thanks
*clarkitekt
Options
- Highlight
- Email to a Friend
04-27-2004 03:52 PM in reply to:
*clarkitekt
Thanks Aaron, this is helpful knowledge and I think I see how to make it
work for me as I don't need to print from AutoCAD. I just need to be able to
see what is what well enough that our none Revit users can use these
exported elevations/sections as backgrounds for details and such. I can just
have them change all the layers to white (or whatever color they prefer) and
then set AutoCAD to show lineweights...
One more question though. Our office uses a standard in which our layers for
linework in elevations and sections are based on the plot thicknesses of
those lines (ie. the thickest (the cut line) is on a layer called
A-Sect-MCut, followed by A-Sect-03, A-Sect-02...) regardless of what object
the line is representing. Is there not a way to correlate those lineweights
to a layer. For instance everything that is cut will come in (acad) on
A-Sect-MCut, then the next thickness of line (shown in Revit) will come in
on a layer called A-Sect-03.
Thanks again,
Brad
"Aaron Rumple" wrote in message
news:408ed2aa$1_1@newsprd01...
setup.
> drawing?
> that
> > layers/weights?
> > Thanks
*Aaron Rumple
Options
- Highlight
- Email to a Friend
04-27-2004 03:59 PM in reply to:
*clarkitekt
For our mechanical group, I set up export views with just the information
they need. The AutoCAD colors colors are all as they like per the
Import/Export settings. Lineweight is retained per Revit, but the color they
use is a halftone color. They get no extra drawing elements, so they have no
layers to manage. With a Selected/View Sheets filter, I can export just what
they need in a few seconds with no effort.
news:408ee42a$1_1@newsprd01...
to
just
and
for
object
lineweights
> Thanks again,
> Brad
plot
look
> setup.
and
> > drawing?
to
> > that
appropriate
> > > layers/weights?
> > > Thanks
*Aaron Rumple
Options
- Highlight
- Email to a Friend
04-27-2004 04:10 PM in reply to:
*clarkitekt
Whoops - forgot answer to main question: Import/Export settings. You may
have to create a special setup for Sections and Elevations to get so
specific, but it should be possible to accomplish what you want.
news:408ee667$1_1@newsprd01...
they
no
what
able
> to
> just
> and
> for
> object
> lineweights
in
> > Thanks again,
> > Brad
> plot
> look
> > setup.
> and
> > > drawing?
section
> to
walls
> > > that
> appropriate
> > > > layers/weights?
> > > > Thanks
