• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Revit Architecture
    Member
    error message
    114 Views, 2 Replies
    05-22-2012 08:33 PM
    I have installed Revit Architectural 2012 and when I press "New" I get the following error message "Attempted to access Default AUSENU.rte past its end". How can this error message be removed and can progress into a new file?
    Please use plain text.
    Valued Mentor
    vector2
    Re: error message
    05-22-2012 08:53 PM in reply to: burr53
    You need to tell Revit where to look for that template.
    Employee
    loboarch
    Re: error message
    05-23-2012 05:20 AM in reply to: burr53
    A "past its end" error typically indicates a file error of some kind.  You will have to resort to a back of that RTE file or re-create the template file.  The original one you are attempting to create a project from has been damaged in some way.
    Jeff Hanson
    Sr. Subject Matter Expert
    Autodesk, Revit User Experience
