Autodesk Revit Architecture
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
cutting a cantilever ed concrete beam at an angle
- Highlight
- Email to a Friend
hello,
anyone can help?
i have a cantilevered concrete rectangular beam cutting across a sloping rc roof.
how do i cut away the beam at an angle perpendicular to the roof slope?
Re: cutting a cantilever ed concrete beam at an angle
- Highlight
- Email to a Friend
Create a Reference Plane in elevation of section at the angle you want to cut the beam.
Then use Cut Geometry to trim the beam.
cheers
Registered Architect/BIM Manager
Thalden Boyd Emery Architects
St. Louis, MO
- Highlight
- Email to a Friend
You can cut the beam in elevation using a slanted reference plane and the Cut Geometry tool in Revit Structure, not in Revit Architecture.
In Revit Architecture, use Opening by face, creating a sketch with a polygon that cuts the beam in that shape, as if it was a void.
See illustration.
Planta1 Revit Online Consulting | info@planta1.com
- Highlight
- Email to a Friend
Alf,
As always, you are correct!
The ref plane cut works for wood and steel beams, but not concrete..............
cheers
Cliff
St. Louis, MO
- Highlight
- Email to a Friend
Dear,
About cutting concrete beams with an angle , the solution :
Go to family editor of the beam.
go to family category and parameters
change the structural material type into steel.
back to the model, use a reference plane and cut.... should work now
gr.
Andy
BIMDESIGN
- Highlight
- Email to a Friend
It solves the cutting, but then you can't get the concrete beam back to be "concrete" material in the family, without getting errors in the project. I wonder if that might cause other issues.
