Autodesk Revit Architecture
Topic Options
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
curtain systems
Options
- Highlight
- Email to a Friend
179 Views, 3 Replies
02-15-2007 02:26 AM
any suggestions on how i can allign the grids and mullions in a curtain system of a curved glass roof?
the picture is attached
thanks in advance
thanks in advance
Re: curtain systems
Options
- Highlight
- Email to a Friend
02-15-2007 10:17 AM in reply to:
smuhic
Pick on the curtain system and you will see a small blue icon or under its properties, there is an offset parameter in both directions, just measure the distance needed and modify this setting.
Re: curtain systems
Options
- Highlight
- Email to a Friend
02-15-2007 11:25 PM in reply to:
smuhic
you know ive tried that already and it worked, although not as i thought. i wanted continuous grid lines through all segments. i thought revit would create a curtain system over all the segments using a single grid and not a grid for each segment, that way the grid lines and after that the mullions would be continuous lines from left to right and bottom to top. i guess i'll just have to live with that or draw the grid line myself.
but the bigger problem is that the windows are placed verticaly on 2 segments and horizontaly on the other 4 segments. to this problem i couldnt find a solution. how to rotate the placing of windows in a curtain system 90 degrees?
Re: curtain systems
Options
- Highlight
- Email to a Friend
09-14-2012 03:55 PM in reply to:
smuhic
I don't have an answer but I was wondering if I could ask you a question. How did you get your mullions and glass to curve along your curtain grid. When I create a curtain grid from mass face my curtain panels and mullions are always straight (like the grid on the left in your image).
