• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    Distinguished Contributor
    break line mask region in Revit 2013
    828 Views, 7 Replies
    09-04-2012 03:17 AM
    Hi I have some sections and am using the break line with a masked region but in Revit 2013 the masked region only works in the Wireframe Graphics display option. It does not work in the Hidden Line display. It was fine in 2012
    Any thoughts
    Cheers Barry
    Please use plain text.
    LisaDrago
    Re: break line mask region in Revit 2013
    09-04-2012 05:21 AM in reply to: Barryfisher
    I have attached 2 images - break - Hid - that is the break component in hidden line mode and the second - BReak - WF is wire frame. It appears opposite of what you are experiencing.
    Can you post some images?
    LD
    If this helped solve your issue - remember to 'accept as solution' to help other find answers!
    You can't think AutoCAD and run Revit.
    Email: lisa@kalblue.com
    09-04-2012 05:47 AM in reply to: LisaDrago
    Images attached...
    Cheers Barry
    LisaDrago
    09-04-2012 05:54 AM in reply to: Barryfisher
    Can you post an image with the break component highlighted?
    See Below
    LD
    09-04-2012 06:07 AM in reply to: LisaDrago
    Attached
    LisaDrago
    09-04-2012 06:34 AM in reply to: Barryfisher
    Nothing jumping out as to why it is reacting this way...
    Is it only in one file or others?
    LD
    09-04-2012 07:00 AM in reply to: LisaDrago
    It is only in this project. I started the project in 2012 and upgraded to 2013 but we have other project that we have done the same to an have no problems.
    We have 2 break line, the standard that works only in Wireframe and then our company standard break line that we normally use. This works in all other projects but does not work at all in this project in either wireframe or hidden.
    Cheers Barry
    09-04-2012 02:07 PM in reply to: Barryfisher
    It could be a filter or a visibility/graphics override that's causing the problem.
    Ross Kirby
    BIM Manager
    Arcturis
