• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Revit Architecture
    Distinguished Contributor
    area takeoff
    165 Views, 5 Replies
    09-19-2012 09:27 AM
    See attached file.
    How can you do the area takeoff of only the selected faces (red area)?
    Right now I have to use the 3rd party software to do something like this.  I'm curious if there's a way to do inside Revit?
    Thanks in advance.
    Please use plain text.
    Alfredo_Medina
    Re: area takeoff
    09-19-2012 10:09 AM in reply to: diesellam
    Paint those 3 faces with a material. Then, in the project, do a material take-off schedule that applies to elements of the same category as this object. That schedule will give you the area per material.
    Planta1 Revit Online Consulting | info@planta1.com
    Re: area takeoff
    09-19-2012 10:13 AM in reply to: diesellam
    This is just an example of the exterior wall.  Your suggestion is good.
    But I have about 1000 of them all over the project.
    This is not a feasible solution if I have to paint the materials for all 1000 of them.
    You can't isolate the faces of the wall in Revit, can you?
    Alfredo_Medina
    Re: area takeoff
    09-19-2012 10:16 AM in reply to: diesellam
    Oh, if it is a wall, you don't need to paint anything, but configure the components of the wall in its type properties. The material take-off schedule should report that information.
    Re: area takeoff
    09-19-2012 02:06 PM in reply to: diesellam
    Would you mind to elaborate a little bit more?
    You mean to apply the material in the wall's type properties?
    Alfredo_Medina
    Re: area takeoff
    09-19-2012 02:45 PM in reply to: diesellam
    Yes. Is it not what you need, to estimate materials in a wall? That's what the material take-off schedule is for.
