• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    Member
    Wireframe and Section
    165 Views, 4 Replies
    01-17-2013 12:58 PM
    I created a kitchen counter in Revit 2011 however, when I try to create a section it does not show what a section should show such as the shelves that are inside the cabinet. It just basically shows what an elevation would show. I checked all my settings and everything is good. What could be the problem? I created another family as well and when I do a section it shows what should be seen in a section. The same thing happens when I put the counter into a project. The section does not show correctly as well as the wireframe visual style does not show in plan view. It show as if it were in hidden line. Any suggestions is greatly appreciated. Thanks!
    Please use plain text.
    LisaDrago
    Re: Wireframe and Section
    01-18-2013 05:56 AM in reply to: paraoan4
    Can you post an image of the problems? That will help to determine what is happening.
    LD
    If this helped solve your issue - remember to 'accept as solution' to help other find answers!
    You can't think AutoCAD and run Revit.
    Email: lisa@kalblue.com
    Member
    01-21-2013 06:39 AM in reply to: LisaDrago
    As requested, attached are images. Image 1 shows the counters in plan in wireframe view (but view is not showing correctly), image 2 is a 3D image in wireframe view (to show what it should look like in wireframe plan view), image 3 corresponds to section 9 (does not show correctly -not cutting through sink and not showing the faucet correctly), and image 4 corresponds to section 10 (it should show two shelves inside).
    Member
    01-21-2013 06:40 AM in reply to: paraoan4
    Image 4
    LisaDrago
    01-21-2013 09:57 AM in reply to: paraoan4
    What is the category of the component? It does not seem to be executable... At least that is my initial thought.
    If you would like to send it and I can take a look you are more then welcome to - my email is below.
    LD
