Autodesk Revit Architecture
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Re: Windows 8 Compatibil ity
- Highlight
- Email to a Friend
- Report Inappropriate Content
Well, that's good to know.. Not that I'm looking for things to lose sleep over, but since the Mayan apocolypse came and went, I guess I'm just naturally looking for something to replace it... ha.
- Highlight
- Email to a Friend
Hi, I am using Revit LT 2013 and having fatal error issues on topo surface creation. Is it a win 8 issue?
- Highlight
- Email to a Friend
Any ideas if Autodesk will make Revit 2012 compatible with Windows 8?
I cannot update some projects to Revit 2013 and new machines have Windows 8.
- Highlight
- Email to a Friend
nope
they may or may not make it compatible
- Highlight
- Email to a Friend
- Highlight
- Email to a Friend
So, I can't use Revit 2013 since I can't save backwards and I need to have my structural model in 2012 to share with my client (architect), who is using 2012 unless I work on a Windows XP or Windows 7 machine. Affectively Autodesk is telling me to not use the most current OS that Microsoft has until my older projects have faded away.
Is there anyway we could get Microsoft & Autodesk to either work together or get in a cage and fight it out winner takes all?![]()
- Highlight
- Email to a Friend
I am running Revit 2013 on a Windows 8 platform very successfully. The only issue I have is a strange floating 'family' dialogue which appears, see:
http://forums.autodesk.com/t5/Autodesk-Revit-Archi
I might be just lucky, but it would suggest other issues, software or hardware configurations perhaps, which are causing the problems being experienced.
Chartered Architect
Robertson Partnership
Truro. UK
- Highlight
- Email to a Friend
jandrews407 wrote:Any ideas if Autodesk will make Revit 2012 compatible with Windows 8?
I have been using both on Windows 8 just fine. Revit 2013 works much nicer with update 2.
Can't complain otherwise with either version.
- Highlight
- Email to a Friend
This is correct. If you are going to use Windows 8 you need to work with Revit 2013 Update 2, otherwise you will get strange ribbon/UI behavior due to an incompatibility with Revit and MS .NET 4.5 which is needed for Windows 8.
Jeff Hanson
Sr. Subject Matter Expert
Autodesk, Revit User Experience
- Highlight
- Email to a Friend
Jeff,
To clarify, Revit 2012 works just fine on Windows 8 also. Just may not be supported, correct? Because I have not had any issues with 2012.
2013 gave me a little trouble before update 2.
