• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    Valued Contributor
    kate_vanhout
    Window Tag Location
    172 Views, 4 Replies
    02-02-2012 09:35 AM
    I have attached an image of where my windows tag are placed by default when I place them on my slider windows.  I have created these windows myself and I have no idea how to adjust the default location of the windows tags... Does anyone know how I can do this?
    Distinguished Mentor
    LisaDrago
    Re: Window Tag Location
    02-04-2012 03:30 PM in reply to: kate_vanhout
    Tag placemet is based on the origion of the family. By default it places the origin of the window tag at the origin of the window family.
    Does that make sense?
    LD
    If this helped solve your issue - remember to 'accept as solution' to help other find answers!
    You can't think AutoCAD and run Revit.
    BLOG: http://swmibim.blogspot.com/
    Email: lisa@kalblue.com
    Valued Contributor
    kate_vanhout
    02-06-2012 05:23 AM in reply to: LisaDrago
    Yes it does, Thank you!
    Valued Contributor
    kate_vanhout
    02-06-2012 08:32 AM in reply to: kate_vanhout
    I have one more questions about this, I changed my origin to the location that I would like tags to be placed, but now my head height is off... how do I fix this?
    LisaDrago
    02-06-2012 11:09 AM in reply to: kate_vanhout
    I would asume it is coming in too low or to high now - in the instance parameters you can change the sill height to raise or lower the window to the right plcement or you can adjust the window in an elevation view.
    It is a little more work - but it is either that or adjust all of your tags.
    LD
