• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    Active Contributor
    Window Family Problems
    112 Views, 2 Replies
    11-12-2012 02:46 AM
    Please see attached Revit File
    I am creating a window, i have inserted a few parameters width , height etc. But when i try and change these widths and heights my upper frame does not move with it. See file for better explaination.
    Any help would be appreciated.
    Please use plain text.
    Re: Window Family Problems
    11-12-2012 12:41 PM in reply to: paul53_7
    In general - get it working with flexing of the reference plane before you worry about the geometry.  Put in reference plane and place only one dimension string to control it. (dont put in multiple dimensions in multiple views to the same plane.   Assign a parameter to control the dimension.  Flex it to ensure the reference plane moves when you change the parameter (maybe have 2 family types for testing/flexing).   Lock geometry to the reference planes and not to other geometry. Good luck.
    Active Contributor
    11-13-2012 12:18 AM in reply to: nddesign
    Would you have any examples you could show me?
    Still abit new to creating families.
    Thanks.
