Autodesk Revit Architecture
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Winder Stairs
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
i have looked through the discussion board and cannot find an answer to How to create a Winder staircase.
The as built staircase is a straight run with the first 3 or 4 treads winding. I cannot figure out what my settings need to be etc. HELP!!
Re: Winder Stairs
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
There are, at least, 2 ways:
- With the stair by sketch method, modify or create risers manually, with the Riser tool.
- WIth the new stairs by component method, use the Winder tool.
Planta1 Revit Online Consulting | info@planta1.com
Re: Winder Stairs
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Al, Thanks that is what i did. I drew the stair boundry and placed the risers in. seemed to work fine. I get the error message below: Stairs require no less than 2 boundries. (the MS paint image dropped some of the risers, trust me they are there)
Re: Winder Stairs
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
See that green horizontal line? That should be a riser (black line), not a boundary (green line). The boundaries areusually two sets of lines, on the sides of the stairs, not intersecting each other.
Re: Winder Stairs
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Why isnt this board (not sure what it is called) not running parallel with the stair case??
