• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Revit Architecture
    jmackniak
    Winder Stairs
    232 Views, 4 Replies
    01-14-2013 09:16 AM
    i have looked through the discussion board and cannot find an answer to How to create a Winder staircase.
    The as built staircase is a straight run with the first 3 or 4 treads winding.  I cannot figure out what my settings need to be etc. HELP!!
    Please use plain text.
    Alfredo_Medina
    Re: Winder Stairs
    01-14-2013 07:06 PM in reply to: jmackniak
    There are, at least, 2 ways:
    • With the stair by sketch method, modify or create risers manually, with the Riser tool.
    • WIth the new stairs by component method, use the Winder tool.
    Planta1 Revit Online Consulting | info@planta1.com
    jmackniak
    Re: Winder Stairs
    01-15-2013 05:34 AM in reply to: jmackniak
    Al,  Thanks that is what i did.  I drew the stair boundry and placed the risers in. seemed to work fine. I get the error message below:  Stairs require no less than 2 boundries. (the MS paint image dropped some of the risers, trust me they are there)revit stairs.png
    Alfredo_Medina
    Re: Winder Stairs
    01-15-2013 05:54 AM in reply to: jmackniak
    See that green horizontal line? That should be a riser (black line), not a boundary (green line). The boundaries areusually two sets of lines, on the sides of the stairs, not intersecting each other.
    jmackniak
    Re: Winder Stairs
    01-17-2013 09:11 AM in reply to: Alfredo_Medina
    Why isnt this board (not sure what it is called) not running parallel with the stair case??revit stairs2.png
