• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    New Member
    Walls drawing tools
    121 Views, 2 Replies
    02-02-2013 10:47 PM
    Just loaded the latest version of REVIT 2013 and noticed that the drawing tools box does not come up when you select "walls"??
    Has this been changed?? Anybody know?
    Grumpygoldie
    Please use plain text.
    Valued Mentor
    AJA14
    Re: Walls drawing tools
    02-03-2013 04:09 AM in reply to: grumpygoldie
    No, the contextual walls tab should show up with the wall drawing tools. Try Repairing or reinstalling.
    Ali Al-Hammoud
    Structural Design Engineer
    MZ & Partners Engineering Consultancy
    Employee
    loboarch
    02-04-2013 05:47 AM in reply to: grumpygoldie
    You need to make sure you have installed the upadte to Revit 2013.  What you are describing sounds a bit like an incompatibility with .NET 4.5 and Revit which causes contextural tabs to not display correctly.
    Jeff Hanson
    Sr. Subject Matter Expert
    Autodesk, Revit User Experience
