• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    Wall wraping material
    178 Views, 2 Replies
    06-30-2012 06:26 AM
    Here we have created a simple mass (image 1) and made walls from the faces (image2). After joining the faces and giving a "wrap around both" material, the brick metrial is not continuous. There is a band of different material seen.
    How can we get the brick to run with no band inbetween.
    Please use plain text.
    Valued Contributor
    Re: Wall wraping material
    06-30-2012 03:27 PM in reply to: abir.acharjee
    Well I guess you are talking about the way two walls intersect, or join.
    The first thing I would do is hit the "Edit Wall Joins" tool.
    Alfredo_Medina
    07-01-2012 05:22 AM in reply to: abir.acharjee
    Edit Wall Join won't work for these slanted joints. The "wrap" setting of the wall type won't help for these joints either. Simply make all the walls with Location line = Finish face: Exterior.
    Planta1 Revit Online Consulting | info@planta1.com
