• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Revit Architecture
    aalonsojaver
    Wall, attach top
    202 Views, 2 Replies
    08-31-2012 01:22 PM
    Exist a way to Attach the top of the wall in a element that is not a floor or roof.
    I have a wall under a stair and i want to make de top of the with a slope.
    thanks!!!
    Please use plain text.
    Active Contributor
    arya2013
    Re: Wall, attach top
    08-31-2012 02:19 PM in reply to: aalonsojaver
    Hi
    Attach the wall with stairs allowing you to do that, but you can use the following method.
    1 - Plan View Ref Plan and draw a name to your propertise window.
    2 - Select the Component Model-In place and Wall Options window, choose a name and press Ok to enter your family.
    3 - Ref Plane to a Set Voied Extrusion method and depth to draw Profile.
    4 - Now, Profile, Cut drawn from Wall least now.
    I hope to help you
