Autodesk Revit Architecture
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Wall and floor connection /cut
- Highlight
- Email to a Friend
I am working with revit for a long time and recently an issue appeared. I was working with mass, then attached walls by face, divided mass into floors, made them. In a section view my wall is with angle to background. I want to connect wall to floor so that none of the floor would be visible outside. I add an image. I was trying to work with cut profile, but it doesn't eliminate all of the problem. I use revit 2012.
Thank you in advance.
Re: Wall and floor connection /cut
- Highlight
- Email to a Friend
In-place floor.
- Highlight
- Email to a Friend
Could you be more specific? i didn't find and don't know how to do it.
could you, please, explain?
Thank you.
- Highlight
- Email to a Friend
Extrude the floor off of a work plane. Select floor category for it.
- Highlight
- Email to a Friend
As i understand, you made section profile of the floor and horizontally extruded. At this point i can not make vertical shafts, is it because you have to vertically extrude floors?; also i can not edit structure of the floor, am i supposed to drow it with region?
thak you.
- Highlight
- Email to a Friend
That's an elevation view of the floor and walls. To make an in-place
floor, draw a reference plane in a level view and give it a name in its
properties. Then go to an elevation view that would be perpendicular
to that plane. Then hit your model in-place command and the first thing
it wants to know is what is this thing you want to build, (category), select
floors. Then hit the extrusion button and it will ask you to select that
plane you just made so it knows what to extrude from. After you finish
this floor you can pull it into different lengths with the grips.
BTW you can't manipulate system floors in strange ways, so you have
to delete them and build in-place floors.
And if you want to make floors that are twisted in really strange shapes,
you will need to learn more about in-place families. In that case it might
be easier to start them in the mass editor.
- Highlight
- Email to a Friend
Still I don't understand if in place floors can be structurally edited - different layers added? And is in place floor being cut with shaft function? The questions are because I didn't manage to to it and I am wondering if it's not possible o I did not find how to.
Thanks.
- Highlight
- Email to a Friend
You can't edit assembly layers for floors
like you can with walls, unless there is
something in the new Revit I haven't seen
yet. But we are not talking about system
floors anyway, we are making fully custom
in-place floors. That means we make every
part of that floor manually. See the image.
- Highlight
- Email to a Friend
Well still the same problems. Should I make a shaft through the modeled floors manually one by one? Also how did you managed to get few layers for the floor? Did you draw several floors in order to get the result?
Thanks.
- Highlight
- Email to a Friend
"layers for the floor?"
Each part of the floor is a separate in-place family.
As they would be in reality.
"shaft through the modeled floors manually one by one?"
Yes every part is created separately.
See the image.
