• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Revit Architecture
    Distinguished Contributor
    RNDPIS
    Wall Sweep
    803 Views, 6 Replies
    12-31-2010 04:31 AM
    Can we turn off the wall sweep in plan view in revit? We have attached a jpg for your help.
    Please use plain text.
    Re: Wall Sweep
    12-31-2010 05:22 AM in reply to: RNDPIS
    One thing you could do is to raise the "Bottom" offset of the Primary Range settings in the View Range to slightly abovr the top of the sweep.
    Michael L. Maloney
    Virtual World Designs
    VDC & BIM Model Design, Clash & Coordination
    mike@VirtualWorldDesigns.com
    Building Design Suite Ultimate 2013
    Charlotte/Gastonia, NC & Jacksonville, Fl.
    RNDPIS
    Re: Wall Sweep
    01-02-2011 08:47 PM in reply to: RNDPIS
    We use this wall sweep as skirting of a wall and it was placed at the bottom of the wall. In this case we uses the default view range setting of revit. We have attached the jpg of the view range setting. Can we change this with visibility graphics? If possible then please suggest us.
    Re: Wall Sweep
    01-03-2011 03:35 AM in reply to: RNDPIS
    In the View Range DB, Under "primaryP, try raising the BOTTOM from 0.0000 to something just above the top of the sweep.
    Michael L. Maloney
    RNDPIS
    Re: Wall Sweep
    01-03-2011 03:55 AM in reply to: RNDPIS
    Thank you for the suggestion, but for a typical architectural plan we have to show everything like flooring, door swing, etc including the skirting. We just want to hide the skirting in particular details. By following your suggestion, the flooring is getting hidden as well. Kindly review and suggest.
    Active Member
    Re: Wall Sweep
    01-03-2011 11:57 AM in reply to: RNDPIS
    can you not right click on the sweeps and select Hide In View/Elements?
    Dave - DDP
    Check out revitforum.org
    RNDPIS
    Re: Wall Sweep
    01-03-2011 08:27 PM in reply to: Dave_Jones_DDP
    We have created this wall sweep with sweep option in wall properties DB. So we can not hide the element.
