• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    Active Contributor
    Accepted Solution
    Wall Sweep to Follow Wall Profile
    582 Views, 3 Replies
    04-12-2012 01:17 PM
    Hello All,
    I was wondering if there is a way to get a wall sweep that's set up in the type/structure properties to follow a wall if that walls profile has changed.  For example, in the image below, I've split the wall and adjusted it's profile to create some cheesy angled parapet.  How do i get my wall cap to follow along?  I thought splitting it and changing it's height would work, but no.  And if I change the profile without splitting the wall the wall cap just runs right through the wall, as if the profiel was never even changed.  I have no idea how to do this and any help would be greatly appreciated.
    ~Wes~
    Please use plain text.
    *Expert Elite*
    Re: Wall Sweep to Follow Wall Profile
    04-12-2012 01:21 PM in reply to: oihadsf
    You can't use a built-in sweep on a Profile Edited wall.
    You can use an in-place family, or a Roof by Extrusion as an alternative method.
    You might also try using a Line-Based Family, with a loaded Profile.
    Cliff B. Collins
    Registered Architect/BIM Manager
    Thalden Boyd Emery Architects
    St. Louis, MO
    Active Contributor
    04-12-2012 01:25 PM in reply to: ccollins
    Cliff,
    Thanks for the quick response.  I was afraid that would be the answer.  I'll look into the other options you've posted and give them a try.
    ~Wes~
    Valued Contributor
    05-09-2012 03:24 PM in reply to: oihadsf
    In-place families work really well for this situation.  I think The Revit Kid had a different method on his blog using reference planes, but in-place families are super easy.  Only advantage to his method was the sweep actually changed when the reference plane changed, but its a lot of work and I never got it to work successfully myself.
