Autodesk Revit Architecture
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
*Rob Starz
Wall Sweep Families
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
306 Views, 3 Replies
01-05-2004 06:55 AM
I have over 150 foam extrusion profiles that I have setup in Revit an I am
trying to create a Wall Sweep family for each one so when a user loads the
library they can just add the wall sweep using this profile. It seems that
users must go then and create a new type for the wall sweep and select the
loaded profile. I create a type in the family but it doesn't load.
Is there an easier way to do this so once loaded the sweep is usable.
Rob Starz
Stardsign cad solutions
www.stardsign.com
*Rob Starz
Re: Wall Sweep Families
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
01-05-2004 08:50 AM in reply to:
*Rob Starz
figured it out.
Rob Starz
www.stardsign.com
ADTcadPacX4 now available for ADT 2004
www.stardsign.com/adtcadpacx.htm
"Rob Starz" wrote in message
news:3ff97ae2$1_3@statler...
that
> Rob Starz
> www.stardsign.com
*Richard M. Piacente
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
01-13-2004 07:26 AM in reply to:
*Rob Starz
Rob,
I am having the same problem. How did you solve it??
Rick Piacente
news:3ff995e4$1_2@statler...
> figured it out.
> Rob Starz
> www.stardsign.com
am
the
> that
the
> > Rob Starz
> > www.stardsign.com
*Rob Starz
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
01-14-2004 07:03 PM in reply to:
*Rob Starz
Bring the profile into a file. Create a wall (any length) then add a wall
sweep to it. Edit the wall sweep and duplicate the sweep type. Name it and
set the correct profile. Exit the dialog and the profile should look fine.
Make sure all your parameters and types are set. Save the file and if you
want users to utilize the wall sweep profile they open the file that
contains the profile it and then transfer families from this file to the new
one. Not simple but it helps set them up and ready to use.
Hope this helps. Sorry if I didn't use the correct terminology. I don't
have Revit open.
Rob Starz
www.stardsign.com
"Richard M. Piacente" wrote in message
news:40040fa6$1_1@statler...
> Rob,
> Rick Piacente
> > figured it out.
> > Rob Starz
> > www.stardsign.com
I
> am
> the
> > that
> the
> > > Rob Starz
> > > www.stardsign.com
