• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    *Mike Maloney
    Wall Mounted 3D Text
    1263 Views, 4 Replies
    08-01-2008 09:42 AM
    Any ideas how to make? For High School name Placard
    Mike Maloney
    RAC 2009
    ACA 2008
    Navisworks 5.5
    Please use plain text.
    *Jeff Hanson \(Autodesk\)
    Re: Wall Mounted 3D Text
    08-01-2008 10:37 AM in reply to: *Mike Maloney
    Use the model text function. If used from an elevation view you can select
    the plane of the wall for the work plane of the model text.
    Jeff Hanson
    Autodesk - AEC Technical Publications
    Manchester, NH
    "Mike Maloney" wrote in message
    news:5996602@discussion.autodesk.com...
    Mike Maloney
    RAC 2009
    ACA 2008
    Navisworks 5.5
    Distinguished Contributor
    08-02-2008 03:58 AM in reply to: *Mike Maloney
    Another technique is to use a Decal which is an image file placed on a Decal background attached to the face or workplane in your model. The Decal only displays when the model is rendered.
    Using model text limits you to any TT text font, but does show up in all views whether hidden line, shaded and rendered.
    Mel Persin, AIA
    AEC Technology Consultant
    Technology to Visualize and Realize Solutions
    Modeling for the Future/Drafting in the Present/Building on the Past
    *Mike Maloney
    08-05-2008 04:24 AM in reply to: *Mike Maloney
    Thanks Guys, I'll try both and report back.
    Mike Maloney
    RAC 2009
    ACA 2008
    Navisworks 5.5
    wrote in message news:5997105@discussion.autodesk.com...
    Mel Persin, AIA
    New Member
    09-05-2012 05:25 PM in reply to: *Mike Maloney
    Você pode criar uma familia de "perfil" colocando o decalque da placa de fundo, inserindo uma imagem da mesma, após isso você pode salvar essa familia. Na hora de modelar, criar parede, editar perfil da parede. Na familia de perfil copie o decalque, e cole no perfil de parede que está sendo editado, finalize a edição e voua la!
