• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    Accepted Solution
    Wall Hosted Element in Linked File
    339 Views, 12 Replies
    12-03-2012 08:06 AM
    I am having trouble working with wall hosted elements.  I have linked the architectural model into my Revit File.  It is now my job to run plumbing.
    However I cannot insert wall hosted elements such as a Wall Hosted emergency shower (attached).  It does not recognize the wall.  I assume this is becuase it is linked into my model.  Is there any way to use the wall from the linked file to host elements such as these?
    Furthermore I am able to use another type of elemnent that is surface mounted.  Can I change the Shower to look for a surface as opposed to a wall?
    Any Help on either topic would be great.
    Please use plain text.
    *Expert Elite*
    Re: Wall Hosted Element in Linked File
    12-03-2012 08:13 AM in reply to: jfitz2020
    You can convert a Wall-Based Family to a Face-Based Family with the following steps:
    1. Create a new Project, draw a Wall, and load the Family into it.
    2. Place one instance of each Type of that Family on the Wall. Save the Project somewhere.
    3. Start another new Project, and Link the previous Project into this one.
    4. Use the Copy/Monitor tools to create a copy of each instance of that Family in the current Project.
    5. The copied Family is now Face-Based. You can now save/export the new Family to a separate file.
    Corey D.        LogoEE.png   AutoCAD user  Revit user
    ⁞|⁞ Please use the Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos functions as appropriate to further enhance the value of these forums. Thank you! ───────────────────────────────────────────────────────────────────────────────────────────
    *Expert Elite*
    Alfredo_Medina
    12-03-2012 08:16 AM in reply to: jfitz2020
    To host families on elements in linked files, you need face-based families. Wall-based families won't attach to linked walls, Ceiling-based families won't attach to linked ceilings,... etc.
    Planta1 Revit Online Consulting | info@planta1.com
    *Expert Elite*
    Alfredo_Medina
    12-03-2012 08:22 AM in reply to: CADastrophe
    Wow, excellent tip ! Thanks, Corey !!
    12-03-2012 08:57 AM in reply to: jfitz2020
    The OP could also just copy/monitor the wall(s) needed for his fixtures....This would give the advantage of actually being notified if the wall(s) in question ado change down the road.....Just another option.
    M
    Michael L. Maloney
    Virtual World Designs
    VDC & BIM Model Design, Clash & Coordination
    mike@VirtualWorldDesigns.com
    Building Design Suite Ultimate 2013
    Charlotte/Gastonia, NC & Jacksonville, Fl.
    12-03-2012 11:27 AM in reply to: mike
    I have not been able to use the Copy/Monityer function for walls.  Can you do this?
    Maybe I am setting up the Link incorreclty??
    Active Contributor
    sagar.londonites
    12-03-2012 08:20 PM in reply to: CADastrophe
    CADastrophe,
    Thanks for the tip, but I have a question. While using the copy-monitor tool, I see only limited category of families that can be copied. Please see attached image.
    Am I missing something? I am trying to convert a wall-based generic model to face-based by using the method you suggested. How to copy the generic model using copy-monitor tool?
    - Sagar
    *Expert Elite*
    12-04-2012 05:36 AM in reply to: sagar.londonites
    You image shows the Copy/Monitor Options dialog, in which there are options only for the few Categories you see. To see the available Categories for Copy/Monitor, click on Coordination Settings.
    If the Family that you wish to convert is not of one of the listed Categories, you can edit the Family prior to starting the process and change its Category to something that you can Copy/Monitor, and the change it back when finished.
    Active Contributor
    sagar.londonites
    12-06-2012 08:06 PM in reply to: CADastrophe
    CADastrophe,
    Thanks for the reply, but I don't seem to have access to those settings as well. Maybe it's related to Revit build. I'm using Revit Architecture. Does it matter? Is it possible those additional categories are available in Revit MEP only?
    - Sagar
    *Expert Elite*
    12-07-2012 05:40 AM in reply to: sagar.londonites
    I think it would have to do with release rather that flavor, as some of the Copy/Monitor improvements are relatively recent. What version of Revit are you using?
