• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    Valued Contributor
    kwihae
    Voids to cut host wall in window family
    506 Views, 1 Replies
    02-16-2012 07:46 AM
    I would like to cut a void into the wall of a host window family.
    When I place a void in the family, it does not cut thought the wall.
    I tried making the void on a plane perpendicular and parallel to the wall plane.  I dont know if this has anything to do with how voids work.  But its not working.
    I also dont have an 'opening' element in the window family.
    help!
    Please use plain text.
    *Expert Elite*
    Re: Voids to cut host wall in window family
    02-16-2012 08:10 AM in reply to: kwihae
    Inside the project, try using Cut Geometry--select the wall, then the window family.
    Does this work?
    cheers
    Cliff B. Collins
    Registered Architect/BIM Manager
    Thalden Boyd Emery Architects
    St. Louis, MO
