Visual Style disabled
How to get back the Visual style which has been disabled?Visual Style Disabled.png
aghis_no
this happens because probably you control the visual style of the view by a view template.
Whatever the view template controls is not available to be modified on a "per view level". You should make your changes on the View template directly and afect all the views controled by this view template.
However, if you detach the view template from the view, the view will keep the current configuration so you can then change the settings on this view.
hope it helps
aghis
Thanks a lot.... 🙂
It does work .
Helped me a lot to understand the Visual style setting and View template configuration.
