Autodesk Revit Architecture
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Views with visible transparen cy of Glass-Mate rials RAC 2013
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi!
We would like to make the transparency of glass-materials visible in views and section-views by using the "realistic style".
During a 3d-view our glass-material looks like transparent.
Isn't it possible for REVIT to display the transparency of materials in views ?![]()
The workaround to hide "glass" by using "overriding visibility" is not possible for us because some of our families and project families are using glass-materials inside (Showcases f.e.).
Thank you in advance,
Bernhard
Software (German) :
RAC 2012+2013
Inventor Pro 2013
AcadM 2012
MaxDesign 2013
Sketchup 8 Pro
Re: Views with visible transparen cy of Glass-Mate rials RAC 2013
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
bernhard.fetzer wrote:
Hi!
We would like to make the transparency of glass-materials visible in views and section-views by using the "realistic style"...
Planta1 Revit Online Consulting | info@planta1.com
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi Alfredo,
Thank you for your reply.
Your suggested solution is not possible to us.
There are two reasons:
1) If you use a "window family" it is not possible to select the glass separately.
So the frame would also shown as transparent.![]()
2) If you use a project family it is not possible to select some enclosed items separately.![]()
For window- and facade-families we use the hide option inside the "overriding visibility menue" (deselect glass f.e.)
Kind regards,
Bernhard
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Yes, you would need to make some changes to the windows if you want to do this. There are at least two options:
- Use windows with shared nested families for the panels. By doing this, the panels could be selected independently from the frames, and then you could make the panels transparent.
- Use embedded curtain wall elements instead of windows. Then, select the panels and make them transparent, as in the illustration above.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi Alfredo,
for now I have a other solution:
We will use the "Override Graphic in View" and change the surface transparancy only onto 1% !
This has affect only to the transparancy (of material with transparancy).
This works also with project families.
Revit is a crazy program ![]()
Bernhard
