• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    Valued Contributor
    View Title Graphics which Stretch
    134 Views, 2 Replies
    10-04-2012 08:02 AM
    Is it possible to create a View Title Family which have objects which stretch? I know I single line can, but I need to have more that moves to match our graphics standards.
    David William Edwards
    Senior Architectural Designer / BIM Manager
    Sherlock, Smith & Adams, Inc.
    Please use plain text.
    Re: View Title Graphics which Stretch
    10-05-2012 07:04 AM in reply to: davidwilliamedwards
    You cannot constrain elements to the dynamic Extension Line of a View Title. You also cannot control the properties of the View Title with Instance Parameters. So, you can recreate the Extension Line within the Family and create Type Parameters to control the length This means that you will have to create a separate Type for every length you wish to have. (We typically employ three "Short", "Standard", and "Wide")
    If you have elements that you show on the end of that extension line (i.e. North Arrow), then use a Reference Line to control the overall distance of that line. Then, you can Group the extraneous elements with that Reference Line so that they will move along with it.
    Corey D.        ADSK_Logo_EE_2013.png    AutoCAD user Revit user
    ⁞|⁞ Please use the Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos functions as appropriate to further enhance the value of these forums. Thank you! ───────────────────────────────────────────────────────────────────────────────────────────
    Valued Contributor
    10-05-2012 07:14 AM in reply to: CADastrophe
    I came to the same conclusions - just verifying that I wasn't missing somethings or a workaround.
    This needs more flexibility especially when you requirements for numerous Title sizes for all View Title types.
    Thanks!
