• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    Active Contributor
    Vertical Mullions cutting through horizontal Cill???
    134 Views, 2 Replies
    10-31-2012 06:56 AM
    Please see attached image:
    How can i get horizontal mullions to cut through vertical instread or reverse?
    Many Thanks.
    Please use plain text.
    Re: Vertical Mullions cutting through horizontal Cill???
    10-31-2012 07:12 AM in reply to: paul53_7
    Click on one end of the sill mulls closest to the vertical center and then clcik on the arrow that appears toconnect to the next one.....need to be in elevation to do this.
    Michael L. Maloney
    Virtual World Designs
    VDC & BIM Model Design, Clash & Coordination
    mike@VirtualWorldDesigns.com
    Building Design Suite Ultimate 2013
    Charlotte/Gastonia, NC & Jacksonville, Fl.
    Active Contributor
    10-31-2012 07:15 AM in reply to: mike
    Thank You. Still very much a beginner.
