• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    Active Contributor
    Underlay - Seeing Elements of Linked Model in Underlay of Host Model
    188 Views, 6 Replies
    02-11-2013 01:54 PM
    Is it possible for the floor plan elements of a Linked Revit model to appear in the reflected ceiling plan of the host model, using Underlay with the view orientation set to RCP?
    For example, I would like to show the furniture and casework in a linked model, on a reflected ceiling plan of the host model. The casework and furniture in the linked model are on an equivalent level in the host model.
    As I am writing this, I had a thought that maybe this only works when the underlay is set to a different level and that I need to just change my RCP view range to be hovering right above the floor...and set the link to underlay.
    Any thoughts/help?
    Thank you
    Please use plain text.
    LisaDrago
    Re: Underlay - Seeing Elements of Linked Model in Underlay of Host Model
    02-15-2013 04:34 AM in reply to: rkuffel
    Possibly changing the view range would help.
    The main thing to consider is that when you are working on a ceiling plan - it cuts through the level and looks up where as a floor plan - it cuts through the level and looks down. So depending upon where the cut plane is you will not be able to see the furniture.
    I have added an image that show how the view range works.
    LD
    If this helped solve your issue - remember to 'accept as solution' to help other find answers!
    You can't think AutoCAD and run Revit.
    Email: lisa@kalblue.com
    Active Contributor
    02-15-2013 07:54 AM in reply to: rkuffel
    Thank you for your reply Lisa. I believe that an underlay will not show any linked model elements. I have confirmed this by creating a small test project. I will post it when I get to work. It is unclear whether this is by design or supposed to behave this way. Since I'm old school, it seems like an underlay should be/show everything on a sheet, but that's another conversation.
    Can anyone else get a link to show in an underlay? Thanks.
    Alfredo_Medina
    02-15-2013 08:00 AM in reply to: rkuffel
    I think you're right. I think the underlay is a property that cannot be "carried over" with a view when the model is inserted as a link in another model.
    Planta1 Revit Online Consulting | info@planta1.com
    Active Contributor
    02-15-2013 08:08 AM in reply to: Alfredo_Medina
    Thanks Alfredo; do you think I should add this to the help wiki?
    Alfredo_Medina
    02-15-2013 09:39 AM in reply to: rkuffel
    Sure, if you find an article that talks about this in the Wiki, you can add this question as a comment to the article. Those comments are usually responded quickly.
    Active Contributor
    02-15-2013 10:01 AM in reply to: Alfredo_Medina
    I added a note here:
    http://wikihelp.autodesk.com/Revit/enu/2013/Help/00001-Revit_He0/1468-Document1468/1630-Use_and_1630...
    Thanks for the help everyone. Sometimes it really helps to know the limitations so one doesn't spend a lot of time on a wild goose chase. I think this is one of those times where knowing the limitation will help save a  user time.
