Autodesk Revit Architecture
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Trusses
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
131 Views, 1 Replies
12-03-2012 11:29 AM
I am laying out a simple structure. Bearing wall to bearing wall is 35’, with a few non bearing walls between the bearing walls. I will be using a truss to span from bearing wall to bearing wall.; Do I need to model the trusses or are their pre-made trusses with ¼”/1’-0” slope some were online.
Re: Trusses
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
12-03-2012 02:00 PM in reply to:
cadmansteve
For the truss, you could start with a flat truss, such as a Pratt. Then do the sloped roof. Then select the truss and use "Attach top/bottom" "Top" and select the roof. The top of the truss will adquire the slope of the roof.
For the different type of wall above roof level, simply stop the lower wall at roof level, and use a different wall type above the roof.
Planta1 Revit Online Consulting | info@planta1.com
