• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    New Member
    lisalldt
    Troubkle placing components
    278 Views, 3 Replies
    08-26-2010 11:21 AM
    Whom ever who can help me with this,
    I'm tgrying to place my range hood component in my east kitchen elevation view and revit will not allow it and when i siwtch to the first floor view to add the componenet it places it in sideways but when i switch to an oppisite view such as south or north view my range hood that goes over the stove in the east view it comes up the right way but when i try and move it into the correct view its shows up sideways still whatver shall i do????
    Please use plain text.
    *Expert Elite*
    LisaDrago
    Re: Troubkle placing components
    08-26-2010 11:28 AM in reply to: lisalldt
    Can you post an image of it?
    is the component based - like ceiling based, wall based, line based?
    LD
    If this helped solve your issue - remember to 'accept as solution' to help other find answers!
    You can't think AutoCAD and run Revit.
    Email: lisa@kalblue.com
    Active Contributor
    12-15-2012 07:10 PM in reply to: lisalldt
    I am having problems with the same component. I downloaded it from Autodesk seek (see attached). How do I get it to display properly in plan and elevation? When I place it in the floor plan, I get this message:
    "None of the created elements are visible in Floor Plan: First Floor View. You may want to check the active view, its Parameters, and Visibility settings, as well as any Plan Regions and their settings."
    When I try to place it in elevation, I get this message:
    "This type of Component cannot be placed in Elevation or Section view"
    I have everything turned on in graphic visibility. What am I missing?
    Active Contributor
    12-15-2012 09:22 PM in reply to: bcarriere
    I figured it out. It was the view range of the first floor plan. I had to adjust the cut plane offset in the view range dialog.:smileyhappy:
