• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Revit Architecture
    New Member
    Toposurfaces
    134 Views, 1 Replies
    10-04-2012 06:55 AM
    I have 2 issues relatedc to Toposurfaces in Revit 2013 (but not specifically to 2013 only):
    1.   I have set up a Hanrailing to create a fence.  When I place this, it will only be able to follow a Level, i.e. horizontally ot a floor, Ramp or Stair via Pick Host.  I would like to see that a Toposurface can be set as a host for a Handrail to generate a handrail (or Fence) that follows the profile of the site or Toposurface.  Does anybody know if this works or if there is a workaround for this.  If not, I would like to enter this into the wishlist for a future release.
    2.   When editing a Toposurface, I would like to have the functionality to generate or place a point on a toposurface that is read from the actually existing toposurface.  This would help greatly when you try to create terraces (Cut & Fill) to place buildings on a site - especially somewhat steeper sites.  Again, is there some workaround for this, appart from creating a row of spotheights under annotate and then edit the points to these values.
    Please use plain text.
    New Member
    Re: Toposurfaces
    10-04-2012 07:42 AM in reply to: heinerd
    Issue No. 2 is resolved - when placing a new point on the toposurface, make sure that relative to surface is selected as opposed to absolute elevation.  It then works exactly as I want it to.
