• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    Valued Contributor
    Accepted Solution
    Topography fill iun section
    145 Views, 1 Replies
    11-02-2012 02:26 AM
    I'm having a bit of trouble.  I have a project that was setup using 2 linked files.  1 for the building and 1 for the site.  I'd decided to merge them into a single central file and I'v merged the site into my building model.
    What I've found is that the topography fill no longer extends more than 3m below the project base point.  The cut line does just not the fill and I have a site whioch is sloping so I need that fill to extend down to the survey point.
    Is there a setting or property I can change that adjusts this?
    Russ
    Russ Green
    Please use plain text.
    Valued Contributor
    Re: Topography fill iun section
    11-02-2012 03:00 AM in reply to: russ.green
    ahh...site settings>elevation of poche base
    Russ Green
