• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    Active Contributor
    To set up worksets, link. or combine both for (3) predominant areas?
    182 Views, 2 Replies
    06-01-2012 09:33 AM
    Currently we are breaking apart a model and the landscape portion of the file, becaue it's becoming to slow to work on even after purging all unused items. We will be linking these files instead creating a workset because the project is almost complete except for some interior rooms.
    Question is for future projects:
    Are we better off linking the landscape part of the model over workset/sharing it?
    Plans are to start worksets this summer and we are not sure on how to go about breaking up the file's (3) major areas  that we will be heavily involved with and those are:
    1.  House models are around 5,000. sq ft.
    2.  interiors -  highly detailed.
    3. Landscapes - Elaborate.
    Any advise on the best work practices for worksets, linking, and or using a combination of to better handle the major (3) above would be greatly appreciated.
    bluicat
    Revit 2013
    Please use plain text.
    Product Support
    Re: To set up worksets, link. or combine both for (3) predominant areas?
    06-27-2012 03:01 PM in reply to: bluicat
    Hi bluicat
    The following technical note has useful information on suggestions for worksets and linking files and when to break up your model into multiple files:
    http://images.autodesk.com/adsk/files/revit_tech_note.pdf
    Here is a similar post on the topic of worksets vs linked files and some suggestions from other users:
    http://forums.autodesk.com/t5/Autodesk-Revit-Architecture/workset-vs-linked-revit-file/td-p/3450814
    http://forums.augi.com/showthread.php?139328-workset-vs-linked-revit-file
    http://www.revitcity.com/forums.php?action=viewthread&thread_id=21735
    You can also find class materials from the AU class "Optimize Model Performance by Using Worksets in Autodesk® Revit® 2012" on au.autodesk.com:
    http://au.autodesk.com/?nd=event_class&session_id=9501&jid=1741924
    Best regards,
    John Lipp
    Support Specialist
    Product Support
    Active Contributor
    06-27-2012 05:04 PM in reply to: john.lipp
    Hi John,
    Thank you for all of the information. It was very helpful.
    Kind regards,
    bluicat
