To set up worksets, link. or combine both for (3) predominant areas?
Sandra.Massa
Sandra.Massa
Currently we are breaking apart a model and the landscape portion of the file, becaue it's becoming to slow to work on even after purging all unused items. We will be linking these files instead creating a workset because the project is almost complete except for some interior rooms.
Question is for future projects:
Are we better off linking the landscape part of the model over workset/sharing it?
Plans are to start worksets this summer and we are not sure on how to go about breaking up the file's (3) major areas  that we will be heavily involved with and those are:
1.  House models are around 5,000. sq ft.
2.  interiors -  highly detailed.
3. Landscapes - Elaborate.
Any advise on the best work practices for worksets, linking, and or using a combination of to better handle the major (3) above would be greatly appreciated.
bluicat
Revit 2013
john.lipp
Hi bluicat
The following technical note has useful information on suggestions for worksets and linking files and when to break up your model into multiple files:
http://images.autodesk.com/adsk/files/revit_tech_note.pdf
Here is a similar post on the topic of worksets vs linked files and some suggestions from other users:
http://forums.autodesk.com/t5/Autodesk-Revit-Architecture/workset-vs-linked-revit-file/td-p/3450814
http://forums.augi.com/showthread.php?139328-workset-vs-linked-revit-file
http://www.revitcity.com/forums.php?action=viewthread&thread_id=21735
You can also find class materials from the AU class "Optimize Model Performance by Using Worksets in Autodesk® Revit® 2012" on au.autodesk.com:
http://au.autodesk.com/?nd=event_class&session_id=9501&jid=1741924
Best regards,
John Lipp
Support Specialist
Product Support
Sandra.Massa
Hi John,
Thank you for all of the information. It was very helpful.
Kind regards,
bluicat
