• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    Valued Contributor
    Surface pattern on walls - cut window
    560 Views, 4 Replies
    03-14-2011 05:22 AM
    I've got a brick wall. surface pattern : horizontal stripes. Cutpattern: solid. Shows just fine.
    I place a window in that wall, cuts it nicely.
    The window has a little setback of 7cm (or 2,2").
    Viewing 3D I notice the setback renders as a solid (cause it get's 'cut'). However I would like see the setback with horizontal stripes.
    Anybody got a workaround for this? (or no workaround but a decent solution).
    3Pinter
    Please use plain text.
    Employee
    Re: Surface pattern on walls - cut window
    03-15-2011 06:35 AM in reply to: Joris3P
    You should be able to get at least 2 sides of the pattern to wrap by editing the wall type > and enabling one of the Wrapping At Inserts settings.
    Video Example: http://screencast.com/t/taI6sswZb
    Please let me know if this helps this condition.
    Thank you,
    Ryan Duell
    Revit Clinic
    @revitclinic
    Valued Contributor
    03-15-2011 07:50 AM in reply to: ryan.duell
    Ty Ryan,
    Your screencast did solve my problem. And created a new problem.
    The exterior wall is wrapped (as I told Revit to do) however the wrapping altered the connection wall-window.
    Current version: not wrapped at inserts.
    This is the wrapped version exterior, which gives good 3d looks but horrible maserony.
    Employee
    03-15-2011 07:55 AM in reply to: Joris3P
    When wrapping, the family is used to determine this condition.  For example, please see the following post:
    http://revitclinic.typepad.com/my_weblog/2011/02/revit-quiz-what-controls-the-wall-wrapping-location...
    Thank you,
    Ryan Duell
    Revit Clinic
    @revitclinic
    Valued Contributor
    03-15-2011 08:05 AM in reply to: ryan.duell
    ahhhhh! PERFECT!
    Learned something new today. Thank you.
    (crap now I can adjust all my window families)
