• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    Active Member
    kobe
    Student Revit Architecture 2012 - no library item available
    793 Views, 10 Replies
    04-11-2012 03:26 AM
    I have the 2012 student version of revit arcitecture and i have no library items, Walss, doors, windows, how do i get access to these items, itried contacting customer support, but they said as it is a student licence they can not help me and to try the discussion boards????
    Someone please help me?
    Please use plain text.
    Valued Mentor
    vector2
    Re: Student Revit Architecture 2012 - no library item available
    04-11-2012 05:59 AM in reply to: kobe
    I think that content is included with the product install.
    Have you checked C Drive>ProgramData>Autodesk>RAC 2012>Libraries?
    Active Member
    kobe
    04-11-2012 02:41 PM in reply to: kobe
    Thank you for your reply.
    I have been through all the folders in the Revit file and there is none that say libraries. Plus when i try to open up a library item, it comes up with nothing available, doesn't even go to a library file?????
    Any other ideas?
    Valued Mentor
    vector2
    04-11-2012 03:58 PM in reply to: kobe
    "I have been through all the folders in the Revit file and there is none that say libraries."
    Is this where you went?
    Active Member
    kobe
    04-11-2012 04:50 PM in reply to: kobe
    Yes the folder wasn't RAC2012 but longer recut architecture.... There was not folder in any of the sub folders called libraries...
    Valued Mentor
    vector2
    04-11-2012 06:18 PM in reply to: kobe
    Could you click on your "local disk C" and then
    Alt+Printscreen and post that image here?
    Active Member
    kobe
    04-11-2012 07:57 PM in reply to: kobe
    I pressed ALT print Screen but it does nothing, do you have any more instructions..... Thanks
    Valued Mentor
    vector2
    04-11-2012 08:32 PM in reply to: kobe
    Press Alt+Printscreen then open Paint and click paste then save as
    to the desktop and post that here.
    Active Member
    kobe
    04-11-2012 09:48 PM in reply to: vector2
    Thank you
    Here is what you asked for i hope...
    Active Member
    kobe
    04-11-2012 09:51 PM in reply to: kobe
    I just found the library folder, but it is definately empty, i have attached a screenshot.
