• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    *JTB
    Still Nothing with Rails!!!
    77 Views, 3 Replies
    08-22-2004 09:13 AM
    I cant create any railing profile, I guess there is something I dont read or type correctly. Please help... I send a file with one of my failures. Thank you all for your time. Dimitris
    Please use plain text.
    *Steve Burri
    Re: Still Nothing with Rails!!!
    08-22-2004 05:55 PM in reply to: *JTB
    Dimitris, If the baluster is not designed to be used on stairs (or to change their angle with stairs) then it is best to either disable (or delete) the "Top Cut Angle" parameter or set it to zero before crating geometry. Attached is your FIXED baluste. -- Regards, Steve Burri Autodesk, Inc Client Support Manager - Revit -------------------------------------------------------------------------------- "JTB" wrote in message news:4128c649_1@newsprd01... > I cant create any railing profile, I guess there is something I dont read or > type correctly. > Please help... > > I send a file with one of my failures. > > Thank you all for your time. > > Dimitris > > > Attachment not added (content type not allowed): "JTB-BALUSTER-XIASTO-FIXED.rfa"
    *Steve Burri
    08-23-2004 05:56 AM in reply to: *JTB
    Here's a zipped version of the file... "Steve Burri" wrote in message news:4129408f_2@newsprd01... Dimitris, If the baluster is not designed to be used on stairs (or to change their angle with stairs) then it is best to either disable (or delete) the "Top Cut Angle" parameter or set it to zero before crating geometry. Attached is your FIXED baluste. -- Regards, Steve Burri Autodesk, Inc Client Support Manager - Revit ------------------------------------------------------------------------------ "JTB" wrote in message news:4128c649_1@newsprd01... > I cant create any railing profile, I guess there is something I dont read or > type correctly. > Please help... > > I send a file with one of my failures. > > Thank you all for your time. > > Dimitris > > >
    *JTB
    08-23-2004 09:39 PM in reply to: *JTB
    Thank you very much, I guess it was the cutting angle...
